Old 7-Dec-2017, 11:32 PM   #2
JoeAZ
Hi Russ,
The tv fool database has been missing major and minor stations
recently. Hard to tell if there are other ABC stations you might try.
You mention you get channel 31. W31DY looks like a translator for
WLOS TV13. If that is correct and assuming the tv fool report is
accurate, you are in a weak signal area for WLOS's main transmitter
signal. That is why there is a translator nearby. The tv fool report
indicates a 2 edge signal at your location. That means the main signal
is reflected away from you twice or more. With the trees and hill,
it is no surprise you are having trouble with WLOS. I doubt any
other antenna will do as well or better. You could try some kind
of amplification but if you are receiving ABC via the Rf31 translator
why go thru the expense and bother????
