Old 4-Dec-2017, 1:52 PM   #80
blackstone
Here is the status as of 8:30 am 12/4/17
The DB8e is hooked directly to the CM3414 amp.
No preamp.
Antenna is 10' off ground.
Best guess approximation of bearing is 218 Magnetic
VHF CM not connected
39 stations on scan.
If this holds I would be extremely happy
Here's what they are with virtual channels and signal strength:
2 KDKA Good
3 WPSU Weak (That's a weird one. Must be picking it off the back of the antenna)
4 WTAE Normal
6 WJAC Good
8 WWCP Weak (VHF)
11 WPXI Normal
16 ION Good
19 WPCW Normal
21 WFMJ Weak
22 WPNT Weak
27 WKBN Weak
40 WPCB Weak
53 WPGH Good
I will try the RCA preamp again with all other conditions the same
blackstone is offline   Reply With Quote
