Old 2-Dec-2017, 9:34 PM   #63
blackstone
I get WWCP with my CM antenna aimed at 215 m/l.
Sometimes pretty good and sometimes not at all.
WTAE is an anomaly for me.
I was never able to get it with my CM but have gotten it a couple times since fooling with the DB8e.
When you look at the terrain coverage map just above, I am right by the bottom of the the "LL" in Hill.
I picked up a cheap RCA preamp today for my testing tomorrow.
If it looks like it improves that signal, I can return it and get a good one.
Also some stuff to mount the Polaroid and move the DB8e to my light pole.
That antenna looks pretty good.
If the Polaroid doesn't work out I may get this one.
Be nice if it had UHF too because I'd try to get WJAC with it too.
They're not far apart.
Under 20 degrees.
I'll report back tomorrow after changes and testing
blackstone is offline   Reply With Quote
