Old 2-Dec-2017, 3:03 AM   #51
Originally Posted by blackstone View Post
Also. the Polaroid would be for only 1 UHF station in a different direction from all the Pittsburgh stations.
There are 6 transmitters I'm trying to capture there.
Oh, I though you said the CM antenna would be for VHF only.
What are the six channels you need, by call sign?
If 5 of the channels from the west are UHF and VHF, and the SE channel is UHF, then you would need a custom combiner to insert the SE UHF channel into the system because combining two UHF channels from different directions is difficult.
If the SE channel is only just for one TV, there is a way to do it that involves a separate coax to that TV and an inexpensive separate tuner.
