Old 27-Nov-2017, 7:29 PM   #6
If it is the Antronix CMC2002H, it should be OK.
Do I need to consider any amplification?
I doubt it, if your report is accurate, and there are no trees or buildings in the signal path. Too much amplification can overload a tuner.
Do either of your TVs have a signal strength indicator?
If you find that the signals OK with just one TV and no splitter, but too weak after splitting, add a CM3410 before the splitter or substitute a CM3412 for the splitter.
