Thanks rabbit73.
I ordered the C2V. My plan is to hold outside 2nd story window and check levels on one TV and then adjust from there.
I'll have a 25 ft RG6 Quad shield from antenna to inside. I will need to split for 2 TV's. One will have a 15ft run and the second will be about 25ft (RG6 Quad shield).
What type of splitter should I use? I currently have a 2 way Antronix (from cable TV). Do I need to consider any amplification?
Thanks
John
