Old 26-Nov-2017, 11:17 PM   #28
OTAFAN
You could use this to seal all your connections:
https://www.amazon.com/Universal-Ele...ords=coax+seal
I have found coax seal to be easy to apply, will last as long as you need it and is easy to remove if necessary. Also keeps moisture out and very UV resistant.
Just a suggestion. Best holiday wishes.....
