Higher gain narrow field VHF-UHF combo to replace CM4228HD?
Hi Guys,
I am mostly satisfied with my two antenna setup... CM4228 facing 145 Mag south, RCA ANT751 facing 330 Mag to get the one channel north. (Rooftop, 35ft AGL) My quest is now to increase gain to pick up one last low power 4kW station on the same 145 Mag path as the rest of the southern stations. I can only get it to come it enough to flash on screen with 10-20% signal bars and then go away. Here is the question: Is there a single combo antenna to replace the CM4228HD that can have narrow beam, that will increase the gain particularly at chan 49 without losing my two VHF stations 8, 10? hdtvprimer's wonderful website shows the possibility of stacking two CM4228, which would fit on my mast for some additional gain, narrowing field would still fit my needs, keep the VHF channels. But I now have two antennas facing south. If the increased backwave from 2x CM4228 would not pull in the channel at 330 degrees, how do I hook up three antennas? Again, is there a combo with more gain than CM4228 out there? Thanks Again, shovel99
Reason: Clarify
