Thread: Attic Rig
Old 19-Nov-2017, 7:02 PM   #13
William P
If the shield, like aluminum foil on cardboard or a metal screen, is above the antenna so that the antenna doesn't "see" the aircraft above, but does see the TV signal, it might help.
So would the aluminum side go up to reflect interference away from the antenna?
Until I turn it to the south it's coming from the side almost as much. I'm not sure which flight path (or both) creates the problem.
William P is offline   Reply With Quote
