Old 18-Nov-2017, 6:09 PM   #7
JoeAZ
Because you are in a valley, most of the signals go right over
your home and antenna. You likely have a two edge signal
on most of your major Tulsa stations. At 70 feet AGL, those
two edge signals turn into Line of Sight and grow much stronger.
You can try going lower and move the antenna around on your
roof but if that doesn't work, you'll need to go higher. Not
necessarily 70 feet above ground level but higher than what you
currently have.
