No but we are in a valley
That would have been good to know sooner. Because of the current issues with the station database, KOTV doesn't appear on your plot so your terrain issue wasn't apparent.
If you have the space on your mast, I'd run the antenna DOWN the mast in 6" decrements to see if you can find a hot layer in KOTV's signal (without breaking something else) before either going to a taller mast or moving it completely and starting over.
