Old 18-Nov-2017, 3:05 PM   #5
okhipfan
Do NOT use an amp, your local signals are far too strong.
Most likely, you simply need to move the antenna. For UHF issues, it might take as little as 6 inches. Or, it might take 6 feet or 6 yards.
That is good to know. I wondered if that would be the case.
Being in a valley, would a higher mast be beneficial? I have made antenna movements between 75 to 95 degrees to capture a better signal with no luck.
okhipfan is offline   Reply With Quote
