So there are antennae that don't pick up vertical interference? 4 bay? Yagi? I guess I need to look into those. The one I have consists of 3 "Bow ties" in various sizes, and a couple of wide narrow loops mounted on edge. All in about 5/16" aluminum tubing. Hmmm.
I found this. It mentions stacking 2 identical antennae. I actuall own 2 of these. i was keeping 2 houses during the storm and wanted TV at both.
Problems with reception may be reported to the FCC, but before contacting the FCC it is recommended that affected persons attempt to troubleshoot possible solutions. Possible solutions for picture flutter involve the homeowner making adjustments to the position of the antenna, purchasing a highly directive television antenna, or using two identical television antennas stacked.Would I connect these with a COAX splitter installed backwards?
