Thread: Attic Rig
Old 17-Nov-2017, 10:46 PM   #4
JoeAZ
The aircraft are probably causing multipath, causing your
signals to drop out momentarily. The broadcast signals
bounce off the aircraft to your antenna, arriving either before
or after the main signal, causing the issues. Have you
tried orienting the antenna to Miami towers? Have you tried
to see what happens when you have an antenna a distance
from your home or up near the roof??? It will take some
experimentation to find a solution but patience and trial and
error usually prevail......
