Old 15-Nov-2017, 5:30 PM   #17
Mo Man
Thank you rabbit73 for your help and evaluation.
If I am understanding you correctly, the RCA antenna is fine and moving the antenna to the chimney might help, but the trees could still be an issue with WNYW. Did mention that an antenna with more gain usually helps. Any suggestions?
In your opinion, should I try the chimney location before upgrading the antenna. Thanks!
Mo Man is offline   Reply With Quote
