Old 15-Nov-2017, 12:04 PM   #15
JoeAZ
[QUOTE=shenrie;59168]JoeAZ, that looks like a easy setup to get going. priced right as well. if I was to get that and setup the house is it better to run the splitter to middle of house and use equal length cables to each tv or is length irrelevant in this scenario? also, is there a recommended splitter? ive purchased at radio shack in the past and lets just say it was less than a stellar piece of equipment.
Without actually being there, it is hard to say what is going to work best with
regard to location of your signal splitter. Length is very, very important.
Keep your cable runs as short as possible. Use RG6 cable and be sure to
ground your system. It can actually improve reception. Not sure who to
recommend on a splitter. You might be best with trial and error. With regard to mounting your antenna. The most convenient location often
times does not produce the best results. Again, trial and error. One
person watching the tv/signal meter and the other moving the antenna
around......
