Old 10-Nov-2017, 4:10 PM   #5
Originally Posted by lobo012847 View Post
As you requested. Channel 35 WOFL in Orlando is not showing on the grid map listing channels in the Orlando area.
Thank you for the report. The TVFool website has been informed of channels missing from many reports. They do not have enough staff to make corrections. The new database that was entered at the beginning of Nov that is used to generate the reports is defective.
I am not registering. I am simply informing you that you do not show a channel -- as requested on this site.
We understand that you are not registering. You would not be able to post if you were not registered.
Here is an extract from a TVFool report that does not show WOFL:
http://www.tvfool.com/?option=com_wr...60ed25a15f7ff1
Here is a report from the FCC DTV Reception map site that does show WOFL:
I suggest you use the FCC site to double check a TVFool report:
https://www.fcc.gov/media/engineering/dtvmaps
The reason why you were instructed to check the other thread is because it gives the explanation and an example as above.
