Thanks ADtech. The DB8e was too heavy anyway. I think the problem with my Milwaukee reception is the signal loss from the long run, the splitter and the 4 tuner DVR(probably not the greatest tuners). It's the reason I got the Kitztech, just haven't installed it yet pending antenna recommendations. So as of right now I'm looking at just keeping the 751 and adding the amp, the C4MAX and possibly adding the amp or the modified DB4e. The cost isn't a consideration and if Chicago is going to be a PIA, it isn't a consideration either. I'm thinking if I can get rock solid Milwaukee, anything off the back side is just gravy. Changing the location isn't really doable though I might be able to raise it a couple feet.
Using the map you e-mailed me the antenna is located at the lower left corner of the house(southwest)
