Old 7-Nov-2017, 1:44 AM   #7
NATURE
Thanks both of you for all your help. Since my markets are almost exactly 180 degrees offset this should be doable. I'm not looking for the most cost effective option and I'm aware that VHF will probably have to be compromised. So if I'm hearing you right ADTech, you would recommend the C4MAX. Now do I point it at Chicago since Milwaukee is closer, or point it at Milwaukee and just make do with what I get out of Chicago? Because of my market locations I was looking for a yagi without a reflector but it seems a vertical panel might be better.
NATURE is offline   Reply With Quote
