Old 6-Nov-2017, 11:55 PM   #5
I'll make it simple for you.
We have two pre-amps. One is suitable for ANYWHERE a preamp may be needed. The other is suitable for locations where there are no strong signals.
The simple rule that I made for our sales staff is that if there is ANY green on the TVFool plot (including FM), then use the Juice. If everything (including FM) is yellow or below, then the PA18 is fine. An FM filter may be needed if there are strong FM signals present regardless of which amp is used.
