Thank you ADTech.
When I run the interactive tool report most stations are in the cyan and blue color area, including WPIX and WNYW. When the signal hits the first mountain here in NJ it goes from Red-yellow-green to cyan and blue. And I'm past the second mountain, which is all cyan and blue. Not good! I attached the interactive map for your reference. Still not sure why the other channels come in and not others if they originate from the same location.
Anyway, next steps? Do I get a stronger pre-amp? Different Antenna? or what? I really want to make this work.
Your help is very much appreciated.
