Old 26-Oct-2017, 8:03 PM   #6
Tango
Ad Tech makes some very good points. In my opinion, the Clearstream
C2Max would be better at UHF with the VHF better with the Winegard
7694p. Either antenna should serve you quite well.
Thanks. Called them and ordered the C2 Max, since he provided a customer service number and the guy on the other end actually knew what he was talking about.
Am I right that if I have an issue with the VHF, or have an issue later when channels are changed, that it's possible to use two antennas and combine them somehow?
Tango is offline   Reply With Quote
