Old 2-Feb-2011, 12:02 PM   #5
John Candle
Tv Antennas and Reception
Do Not put the indoor Tv antenna on top of the Tv. Do Not put the indoor antenna on top of a stack of electronic devices. Do Not put the indoor Tv antenna on top of or close to a computer. Do Not put the indoor Tv antenna behind a entertainment center , you can put the indoor Tv antenna on Top of a entertainment center in such a way that it clear of obstructions and can be adjusted to face and receive the Tv stations. If a longer coax cable is needed to get the NON Amplified Tv Antenna away from obstructions and devices that cause interference then can use coax and a barrel coupler (inline coax coupler) they are called barrels because they look like 'barrels'.
