Old 17-Oct-2017, 9:28 PM   #16
jrgagne99
Originally Posted by Dude View Post
My signal strength is 'Very Good' for the ABC, PBS and FOX affiliates, while the NBC affiliate (real-36) is a "Good' signal as is the CW affiliate (Real 45), which has CBS in SD (62.2).
It's impressive that WYFF (Real-36) is coming in so strong, given an attic installation and a noise margin of only -6.9 dB. I had to go to 55-ft AGL and a much more powerful antenna to pull in a similar signal in my location. I think you found a nice little hot spot up there. Either that or the FCC report is wrong. In any case, getting all 5 networks plus The CW is a nice result. Good job.
