Old 17-Oct-2017, 7:14 PM   #99
Just out of curiosity, does anyone know if there is a UVSJ that passes power on both ports?
No, but it wouldn't be hard to modify ours so it would do so. It would involve opening it up and soldering a coil between the VHF in and the common port terminals, just like the internal UHF filter is bypassed.
You can also use two SAT/TV diplexers in a back-to-back configuration to bypass a non-power-passing component.
If so, does anyone know of a pre-amp system that can power two pre-amps using just one power inserter?
I have both a distribution amp in my attic and a preamp out on the mast running from a single power inserter in my living room. I'd have to go up in the attic and review how I did it, I just threw it together out of what I had in the "junk box" and it probably wouldn't be the "optimized" solution.
