Old 10-Oct-2017, 2:05 PM   #4
JoeAZ
With the trees and the hill, I believe the TV Fool estimate is
overly generous for your location. The signals are likely much
weaker. The Winegard 7694p and Clearstream 2V come to
mind as good choices for you. The real issue will be finding
a "sweet" spot on your roof, away from the trees, where the
signals are strongest. Your primary signals are Northwest
with Fox/PBS to the Northeast. A rotor or two antennas may
be necessary to get all your stations. Invest in good RG6
cable, keeping the length at or under 50 feet to one tv at
first. Add other tv's later, once you've got good reception
established. Don't forget to ground your system. It can
improve reception and reduces the chance of a strike.
