Old 9-Oct-2017, 1:37 PM   #92
jrgagne99
Where is that building as related to the house, or is it part of the house?
That is my maple sugarhouse, which is part of my barn. The house is located about 100 feet off the left edge of the photo (130 feet between house and tree).
I buried the coax about 18" deep in a 1" black water-pipe and grounded the mast and coax this weekend. I was only able to get about 4-feet deep with the grounding rod, hopefully that is enough.
Question: Does it matter where the grounding block is located, with respect to my Kitz-tech KT-200 pre-amp (upstream or downstream from it). I currently have the grounding block downstream from the pre-amp, since that would be the prototypical configuration if the pre-amp were mast-mounted. But since my pre-amp is at the base of the tree, I appear to have a choice...
