If you will like to watch Tv , answer these questions --> all of the questions. Is the place where you live the same place as the Tv's are at. Is this a , house , Apt. , condo , mobile home , motor home ?? How many stories does the building have ?? Does the building have a basement and if so are any Tv's in the basement ?? What stories do you live in and on , the basement the first floor the second floor the third floor etc. ?? Is the building wrapped with metal such as but not limited to metal siding or stucko with stucko WIRE ?? Does the structure have a metal roof ?? Does the roof have solar panels ?? Is there foil backed insulation in the building ?? Is the building made of poured concrete ?? Is the building wrapped with brick ?? Metal , absorbs , blocks and reflects Tv and radio transmissions. Thick walls made of poured concrete an brick , absorb , block and reflect Tv and radio transmissions. If the building is made of wood with wood siding or non metalic composite siding then that is the best.
