Old 29-Sep-2017, 1:02 PM   #10
JoeAZ
Greetings,
Now I have a more complete picture. You are likely to have greater
long term success with a roof mount antenna. The additional height
will give you better reception over the trees now and into the future.
Someone will need to stand on your roof, holding the mast with the
antenna attached. A new RG6 should be connected via a window or
door to one television. Pointing the antenna to the SW, perform
scans as the antenna is held in one position. Be certain to log/record
your results and the exact position/location of the antenna/mast.
A ten foot mast would be a reasonable height but probably will require
guy wires to be secure in high winds.
