Old 28-Sep-2017, 4:06 PM   #13
Dude
I was able to pull in WYFF (real-36) when pointed at 158 through 254, but WSPA never came in. I tested it at several different positions trying to pickup one of WSPA's translators.
As I said in my first post, before installing this this Winegard Antenna and Amp, I borrowed a neighbors smaller "Amazon-special" antenna and got the same results. WLOS, WUNF, WHNS came in Very Good, while WYCW and WYFF came in Good.
Since I can get the same reception using a smaller antenna (at least this is my understanding after the various trial-n-errors) I ordered the Winegard HD7649P and will use it with CM-5020 amp.
I may even try an attic install since that smaller 1byone antenna pulled in all the above stations when I tested it (except of course WSPA).
I'll do an update later.
Dude is offline   Reply With Quote
