Old 28-Sep-2017, 4:04 PM   #5
ohazco
The trees and the 1 and 2 edge signals will be a bit of a challenge.
The Winegard 7694p at Solid Signal is a very good choice. I would suggest a "J" mount as far away as possible from the trees in the 188 degree direction. Keep the RG6 cable as short as possible, under 50 feet. Connect to only one TV at first, adding others, later. The other antennas you mentioned are either junk or not powerful enough in that situation.
Thanks Joe!!
Here is a picture from the yard looking toward the signals... with everything I'm learning about trees and UHF I'm suprised to hear he got such good reception with an indoor antenna sitting outside at ground level.
ohazco is offline   Reply With Quote
