Old 27-Sep-2017, 3:02 AM   #2
JoeAZ
Greetings Annette,
Your best option would be the Winegard 7694p readily available online
at places like Home Depot.com and Walmart.com. You need to keep
the antenna as far as possible away from trees to the Southwest, which
would block reception. You could use a "J" mount on the eave or facia
of your home. Keep the RG6 cable runs as short as possible, under 50
feet. You MAY need some kind of amplification and/or splitter for the
three tv's. This should help get you started.....
