A 4 bay UHF aimed at Erie with a VHF aimed at CTV is an easy compromise. The question is how to combine them. The sure way is inside the RCA preamp, but you'd probably lose NBC.
A splitter used backwards is doubtful in your case, but it's worth a try. A UVSJ might work OK if your CTV signal is strong enough without a preamp.
