Old 23-Sep-2017, 8:43 PM   #18
Eldorado
The Winegard HD7696P has been discontinued by the manufacturer, but some dealers still have it in stock.
If you want a smaller antenna for CTV on the satellite mount, I suggest the HD7694P. There are some trees in that direction, but I don't know how high they are now. I picked a house at random in your postal code.
Excellent thanks! I am higher up from the point you used and should clear those trees easily
Would that antenna be in replacement of or in addition to my CM4228?
Since CTV is rather close, would I be ok just aiming at the Toronto tower and adding on one of those little VHF kits... I guess depends if you were suggesting the Winegard to be replacement or not, and if the Winegard could potentially pick up both towers
Eldorado is offline   Reply With Quote
