Old 23-Sep-2017, 7:33 PM   #2
JoeAZ
Greetings,
For starters, I would temporarily lose the combiner and run from your
VHF antenna directly to the tv set. If a good signal and picture appears,
you know the combiner may be the issue. The combiner may not be
defective but instead, just doesn't work properly in your particular
application. I personally avoid combiners and run two/three cables,
one for each antenna, to each tv. If a good signal/picture does not
appear, you may have a bad balun or VHF antenna. Hope this helps...
