Old 17-Sep-2017, 10:54 PM   #16
Frugal1SBM
Thank you all for the assistance. I now have the recommended 2MAX antenna above the roof elevated. It is oriented to the recommended 322 degrees with the reflector to the NW and helix to the SE. I get all the channels in the pink to green range. I would like to get some of the yellow range. I had a delay while working out with the HOA who could come to do the install. The dish antenna was removed and a tall antenna pole put in its place. Would the attenuator do anything to pull in those additional signals? It seems we are well balanced for the rest.
Frugal1SBM is offline   Reply With Quote
