The coax cable and grounding block can be reused if they've not been damaged or filled with water. You might get lucky and find a splitter rated for 5 - 2000 MHz. The rest of the satellite distribution components are designed to operate at frequencies above the OTA broadcast bands. Diplexers and switches will be of no value in the OTA system.
