Old 7-Sep-2017, 4:07 PM   #2
Jake V
1. If you originally received a few channels but now don't it could be that the trees have grown or the connections have come loose. My first task would be to check the connections. And check that there are no crimps in the coax.
2. Is the antenna pointed roughly to 215-220 degrees, measured with real compass? What does the antenna look through? Trees, buildings, etc. You might post a photo from the top of the antenna looking towards 215-220 degrees.
3. Make another map at 25 feet. Post the URL of the final map, not an image. Use these directions: http://forum.tvfool.com/showthread.php?t=14508
