Old 6-Sep-2017, 6:51 PM   #18
shovel99
Talking Thanks. I will tell my neighbor ADTech told me to cut his trees.
If the signal path was through trees and reception went faulty particularly when it rained, the problem is the trees. A different antenna is unlikely to change that.
What is likely needed, if available, is a signal path that is not through trees.
Thanks for the advice. I do appreciate your honesty. However, realizing that it has a good chance of being a lost cause, I am willing to throw another $100 Hail Mary pass at another antenna to pair with the CM4228. Which Antennas Direct antenna wold that be, with high directionality, real channel 31, apparently UHF?
shovel99
shovel99 is offline   Reply With Quote
