Old 31-Aug-2017, 3:16 AM   #19
I suggest you try the Solid Signal HDB91X and a good preamp for WUTV at 25 feet. The last time I checked, it was on sale.
http://www.solidsignal.com/pview.asp?p=hdb91x
Your G-H antenna doesn't have enough gain for WUTV.
It also doesn't have enough gain for VHF-High channel 12, even with NARODs, unless you built a VHF G-H like this:
For 7 and 9, try an MCM 30-2476 and a good preamp. VHF signals can get through trees better than UHF signals. It should get better after the leaves fall.
scroll down to Trees and UHF
If you can go higher, then Richmond looks better. Maybe WWBT 12 with the 30-2476 and a good preamp.
