Old 1-Feb-2011, 5:47 PM   #12
Good antenna for UHF close to the transmitters. It lacks support for VHF though.
The previously mentioned HBU-33 is more antenna than needed. An RCA ANT-751 is designed to cover all of the UHF channels plus the high VHF channels 7 through 13. Another antenna to consider would be a Winegard FV-HD30. Both are somewhat directional but not to the point of causing you to loose access to the strong local stations.
I expect that either of these antennas mounted outside will receive so much signal, that you will need to use some attenuation.
