Old 29-Aug-2017, 1:28 AM   #6
mikecandu
I'd use an 8 bay like the DB8E or a CM-4228HD and point it towards the UHF CW station. I'd then point a VHF antenna like The Clearstream 5 towards the VHF stations at 347 degrees. I'd use the Channel Master Hi gain amp and feed it into a UHF/VHF combiner. I'd get a tower and put the antenna up as high as you can afford.
Another option is to put a big piece of metal in the air like the CM 5020 Masterpiece 100 on a rotor so you can rotate towards the station you want. Use a high gain amp.
After all that you'd still be lucky to get about 3 stations.
mikecandu is offline   Reply With Quote
