Old 28-Aug-2017, 11:18 PM   #7
JoeAZ
I've been testing an FM antenna for use with Rf 6 for the past few weeks.
So far, it has worked very, very well even though there are two 58 kw
FM stations on the same mountain top as the 500 watt TV translator. You
might consider an FM antenna for your NBC on Rf 5, WCYB. For your CBS
on Rf 11, WJHL, you might consider a high VHF antenna. MCM Electronics
has the 30-2460 FM antenna and the 30-2475 Hi VHF antenna. Both are
fairly small, light and inexpensive. The other option would be to go
as AD Tech suggests, one large combo antenna. You can get an RCA
branded combo antenna from Walmart for less than $70.00 including
shipping......and it includes the mast!
https://www.walmart.com/ip/RCA-Outdo...d-HDTV/872034?
