Old 28-Aug-2017, 3:19 PM   #1
BarberSurgeon16
Please Advise: Weak Signal, even woth trying more?
Friend has moved location and previously had dish. Was interested in OTA, so I said I would bring over my basic Hoverman-Grey and my cheapy amp to see if we could get anything. Ran from existing roof mount, @25ft above ground.
No channels came up on search. Antenna pointed to try to pull in Fox and At least CW between 250* and 260*.
Location is at bottom of a hill, and there are trees. I figured if we could at least get CW, I might try a different amp or add a reflector to my antenna to try to pull is something additional. At my house I can get all the stations out of richmond, with an attic mount my line of sight is much better, and better signal over all.
So here's the location search results:
http://www.tvfool.com/?option=com_wr...e6a4f472e6c14d
Was thinking of a Channelmaster Signal amp, possibly could get another 5 feet up with another mast and mount improvements. When Analog broadcast was OTA, they got most of the richmond networks at this location.
If nothing I do is going to get a usable signal here, I'd rather not waste time and money for no return.
BarberSurgeon16 is offline   Reply With Quote
