Old 27-Aug-2017, 6:19 PM   #2
JoeAZ
Greetings!
No one antenna is likely to work well is your situation.
For your signals to the S.E., I'd recommend a 4 bay
UHF antenna since all your signals are UHF and are
likely to remain that way. MCM Electronics carries
a 4 Bay for less than$30.00 Antenna Direct also
carries similar antennas. For your stations to the
North, I'd suggest either a Winegard 7694p or better,
Winegard 7698p. Tampa has VHF signals and that
will likely continue. Depending on who you ask,
you'll get really different suggestions on how to
get all those signals to your televisions. I prefer
an A/B switch with two cables running from your
antennas to two distribution amplifiers. It
reduces the chance of other problems. It may
also require a separate tuner for your televisions.
Some sets tuners allow you to add channels
making a separate tuner unnecessary.
