I would expect that stacked antennas in a swaying tree would be counterproductive. The extra gain would help only on calm days. If the height helps, you may not need the extra stacking gain. If you want to try mounting the preamp lower on the tree, I'd suggest a run of RG-11 coax between the antenna and the preamp.
