Old 25-Aug-2017, 8:23 PM   #6
Nurl
So as of current I'm thinking I may want to try the ClearStream 4MAX UHF/VHF Indoor/Outdoor HDTV Antenna and ,if needed, maybe add in a
ClearStream JUICE UHF/VHF AMPLIFIER.
Would this setup work for me? I know it can be hard to say for sure and some of it is still up to manual testing in person, but from what i can tell (again, very inexperienced) this should be "good enough" to pull in the channels I am wanting.
I do have a few trees around my house that may be a concern, but I am hopeful that i can shoot around them if i position the antenna carefully on my roof. The main problem is there is a fairly large tree that would be nearly straight in front of where I need to be aiming and since its on the neighbors property there wouldn't be any options to trim it back and out of the way (besides it would be nearly impossible to trim back in a way to help me anyway).
Still open to suggestions, but as long as i'm not completely off base on this plan i'll probably start there.
Nurl is offline   Reply With Quote
