Old 25-Aug-2017, 6:00 PM   #5
Nurl
Which three?
These 3 ideally, however CBS and NBC are the big ones, i could care less about the IND:
I'd assume that you want the two VHF stations, but are you serious about getting any of the UHF stations from Quincy? You might want to take a look at the content to be sure the effort needed matches your desire for the stations.
You are right - the 2 VHF stations would be the most important, the UHF is fairly trivial and if it would require additional work or extreme measures i'd rather not worry about it.
How about PBS? your only viable options are for KIIN translators out of IA and they're going to require considerably more effort.
PBS would be great, but i realize its probably not going to happen from my location - during a freak event around a month ago i was somehow picking up a PBS station on my indoor antenna, but clearly that was a fluke so not expected or required (although it would be nice if possible).
FWIW, our recent summer intern is a business student in Kirksville. I gave him an Eclipse to use in his off-campus apartment for the two local stations. He said it works fine for him.
Correct, it seems almost anything will pick up the 2 local stations (6 channels total) and i have those without concern, i'm just looking for a way to get the CBS/NBC stations from Quincy as my main goal.
Nurl is offline   Reply With Quote
