Old 25-Aug-2017, 3:10 AM   #1
Nurl
Need help picking out a setup.
Heres my location and results:
http://www.tvfool.com/?option=com_wr...e6a4858299c0a1
I currently have a cheap indoor antenna that receives the channels in green, but I am looking for something to get the channels in pink/red (67 miles away)
Ideally i want to get the channels at 102/103 degrees on the report, the one listed at 25 degrees (75 miles) in red is not needed since its the same (i believe) as the one at 25 degrees but only 3.3 miles away. (They are both Fox-KYOU it appears)
I am looking for a new setup that will be capable of reaching the 3 channels in pink, while maintaining the ability to pull in the 2 green channels. Ideally without needing to rotate.
I have not purchased anything as of yet for my outdoor antenna, but i have asked on facebook (curious about what others in the location did) and was given these two items as an option:
http://www.channelmaster.com/Digital..._p/cm-3020.htm
http://www.channelmaster.com/TV_Ante..._p/cm-7777.htm
Would this setup work? Is there a cheaper alternative?
The person that suggested this setup is also about 15 miles south of my location, but would still be almost the exact same distance away.
Disclaimer: I do not have any experience installing other than some reading online, but my plan is to put the antenna on my roof and tap into the existing wiring that has been ran for a satellite dish that is not in use.
Feel free to ask any questions, ideally i'd like to keep the setup under 100-150, but i realize for a long distance setup like this it can be more expensive.
Nurl is offline   Reply With Quote
