Old 25-Aug-2017, 12:01 AM   #5
JoeAZ
The trees are most likely blocking your signals. Is there a way to
position the antenna in the attic or elsewhere where the trees
are less of a factor??? 100 feet of cable is awfully long. Can you
shorten the cable??? Are you using RG6 cable? I do not find any
VHF signal at 180 degrees. What are the call letters??? Virtually
all your signals are UHF. You do not need another antenna.
I would advise adding any other televisions until you have your
current situation resolved..... Hope this makes sense and is
helpful.
